Problem with Health Monitor
I have a monitor that accidentally has a space in the string:
Get /inservice.txt HTTP/1.1 server.name.com\r\n Connection: Close\r\n
It should be Get /inservice.txt HTTP/1.1 server.name.com\r\nConnection: Close\r\n
no space between \r\n and Connection:
The problem is it is working on the servers now ONLY after a server upgrade did it
fail.  I just want to understand why that space caused the problem after the upgrade.......THANK YOU!
I did test this…
rdexec 2 telnet 10.10.10.10 32100 GET /inservice.txt HTTP/1.1 Host: server.name.com Connection:close
HTTP/1/1 200 OK
rdexec 2 telnet 10.10.10.10 32100 GET /inservice.txt HTTP/1.1 Host: server.name.com Connection:close HTTP/1/1 200 OK
AFTER SERVER CODE UPGRADE: rdexec 2 telnet 10.10.10.10 32100 GET /inservice.txt HTTP/1.1 Host: server.name.com Connection:close HTTP/1/1 200 OK
rdexec 2 telnet 10.10.10.10 32100 GET /inservice.txt HTTP/1.1 Host: server.name.com Connection:close HTTP/1/1 400 Bad Request
This would be the server software and not the F5. Perhaps you would have more luck asking this question in their forum? :slight_smile:
/Patrik
