Problem with F5 Linux Client and AWS Cloud Instance
Hello,
i am not sure whether this forum is the right one. I have a problem with the F5 VPN Client running on a AWS RHEL 5.9 Instance. If I try to create a connection to the corporate network, it gets stucked at the point connecting. Furhter investigations revealed that after the SSL handshacke there is a “Encrypted Alert” which indicates a SSL error. If I try the complete identical configuration on a local machine, it works perfectly. Is that issue known? Are there any switches to activate debugging for the linux client? It is definitely not a certificate problem, because it is the identical configuration as on the local machine.
Any help is higly appreciated!
Kind Regards,
Alex
Hi Alex,
Can you use ssldump to decode a tcpdump and get more info on the error?
SOL10209 - Overview of packet tracing with the ssldump utility
Aaron
