Problem with console display
Dear all,
I have Big-IP 3400, and when I use console, I don’t know to adjust the display screen so I can view all information. I capture the console display in attached file. Could you help me to fix it. Thanks you in advance,
Hut98
You can use Firefox which doesn’t have this issue. Or in IE, you can select text in the window with your mouse and then drag to the left to see the text that’s not displayed by default
Aaron
