Problem with bots redirect
We have defined a robots class, and if any user agent matches an entry in robots class then it redirected to a pool. But the problem is that we want to redirect the traffic to different pool when the agent is googlebot and specific uri then redirect to a different pool altogether. How do we do this.
The irule for bots is as below
when HTTP_REQUEST { if { [matchclass [HTTP::header User-Agent] contains robots] } { pool NeimansBOT } }
and additional condition is that if there ia request coming from /blog (which is the URI part) and the agent is googlebot then redirect it to different pool.
Can we have the logic defined as
if { ([matchclass [string tolower [HTTP::header User-Agent]] contains googlebot]) and ([HTTP::uri] contains “/blog”)} { pool xyz }
elseif { [matchclass [HTTP::header User-Agent] contains robots] } { pool NeimansBOT } }
i think the irule could be okay.
anyway, according to sol9800, the irule should select a pool under every possible condition.
sol9800: Using an iRule to load balance HTTP requests to multiple pools
e.g.
   if { ([matchclass [string tolower [HTTP::header User-Agent]] contains googlebot]) and ([HTTP::uri] contains "/blog")} {
      pool xyz
   } elseif { [matchclass [string tolower [HTTP::header User-Agent]] contains robots] } {
      pool NeimansBOT
      pool default_pool
