Problem with a CLI prompt when trying to show running-configuration
Hello! I am having a problem with two of our F5s when I try to save the configuration with Solarwinds. Somehow they are prompting for confirmation when the “show running-configuration all-properties” is entered. This causes Solarwinds to wait and eventually time our. The problem doesn’t happen on my other F5s. I looked at the parameters for the accounts used by Solarwinds and they are identical. Is there a CLI setting I might have overlooked, maybe?
Thank you!
This usually happens when your control/data plane usage (cpu) is overloaded.
I recommend you to check your cpu usage an also check what process is consuming more. Use this command.
​# top (use “1” to expand individual cpu usage)
KR,
Dario.
Sorry, this command doesn’t work. Also, I don’t think it’s a CPU load issue, this F5 is pratically asleep.
Sorry again, I logged in as root instead of the account that has the trouble and TOP worked. As I tought, the most CPU-hungry process was using 20%.
Then it seems you are facing an bug. I think maybe this probably fits. Check your release.
There are other related bugs but I don’t think they are more suitable than the previous one. Check them anyway.
Also, If I were you I would start rebooting the device. Let me know if this helps.
KR,
​Dario.
Found the solution. I had to do modify cli preference pager disabled display-threshold 0 and modify cli preference pager disabled
Once I did that, I was able to download the config through Solarwinds!
Thanks for the help.
