Problem to convert partition to volume on bigip 3400
Hi everybody,
I’am sorry for my english which is not great but i try explain my problem.
I meet a problem to convert hard disk from partion to volume. The conversion don’t occur as desired.
We have a bigIp 3400 with this configuration :
[fguney@WISPBAGNXB98:Standby] ~ switchboot -l
Current boot image:
HD1.1 - title BIG-IP 10.2.4 Build 655.0
Default boot image:
Available boot image(s):
CF1.1 - title BIG-IP 9.1.0 Build 6.2
So, I followed procedure to convert hard disk to LVM (image2disk --format=volumes BIGIP-10.2.4.577.0.iso) and everything happened good until that installation stopped when it tried to copy a package named "fwmgr_bios-predator-10.2.4-577.0.i686.rpm
info: Selected product requires a minimum of 1024 MiB of ram.
info: License entitlement check; pvd = 20101001, scd = 20130131
info: Begin Install: BIG-IP 10.2.4 build 577.0 from BIGIP-10.2.4.577.0.iso to ,
info: Updating maintenance OS.
info: No MOS update necessary; system has 2.7.3 - 19.0, media has 2.7.3 - 19.0
info: Rebooting to MOS…
Broadcast message from root (ttyS0) (Thu Jan 31 16:14:25 2013):
The system is going down for reboot NOW!
INIT: Switching to runlevel: 6 (reboot)
INIT: Sending processes the TERM signal
Terminal error: Shutting down smartd: [ OK ]
Setting sccp state
Using bigstart to shutdown Big-IP: terminate called after throwing an instance of ‘std::logic_error’
what(): Dead Reference Detected
terminate called recursively
info: copying package i686/fwmgr_bios-apollo-10.2.4-577.0.i686.rpm
debug: copied /mnt/tm_install/1164.afDQck/BIGIP1024/i686/fwmgr_bios-apollo-10.2.4-577.0.i686.rpm
info: copying package i686/lcdproc-mercury-0.5.2-4.fc9.17.0.i686.rpm
debug: copied /mnt/tm_install/1164.afDQck/BIGIP1024/i686/lcdproc-mercury-0.5.2-4.fc9.17.0.i686.rpm
info: copying package noarch/perl-Config-General-2.38-1.fc9.17.0.noarch.rpm
debug: copied /mnt/tm_install/1164.afDQck/BIGIP1024/noarch/perl-Config-General-2.38-1.fc9.17.0.noarch.rpm
info: copying package noarch/perl-Class-Data-Inheritable-0.04-17.0.noarch.rpm
debug: copied /mnt/tm_install/1164.afDQck/BIGIP1024/noarch/perl-Class-Data-Inheritable-0.04-17.0.noarch.rpm
info: copying package noarch/perl-version-0.64-17.0.noarch.rpm
debug: copied /mnt/tm_install/1164.afDQck/BIGIP1024/noarch/perl-version-0.64-17.0.noarch.rpm
info: copying package i686/lcdproc-gemini-0.5.2-4.fc9.17.0.i686.rpm
debug: copied /mnt/tm_install/1164.afDQck/BIGIP1024/i686/lcdproc-gemini-0.5.2-4.fc9.17.0.i686.rpm
info: copying package i686/fwmgr_bios-predator-10.2.4-577.0.i686.rpm
and after nothing.
Could you help me please? I don’t find anything about this issue.
Thank you for your contribution
