Problem Login Firepass with the Client API
I’m trying to use the Firepass client via the f5fpapi dll and I have issues with it.
When I call OpenSession, I receive the _IAppTunnelEventsEx_OnOpenSessionFailedEventHandler event with the message “Access is denied” and the error 0x80070005. The authentication is made by certificate and I have to choose it after the OpenSession so I reached the server.
When I use the CLI client with the same parameters I have no problem.
I don’t know if it’s an issue in my code or in the server configuration.
Does anyone already had this problem ?
Hi Spa~ I realize this is a few years old but I’ve been going thru the old FirePass questions…
Not positive if you even need help anymore but this might be your issue:
SOL11764: SDK needs two .dll files to run correctly - 404 Page not found | BIG-IP Documentation
hope that helps although you may have upgraded to APM by now.
ps
