Problem inserting client cert
Hello,
I am trying to implement SOL5171, where I insert a client certificate into the header of an HTTP session.
Here is the iRule:
if {[SSL::cert count] > 0} {
HTTP::header replace SSLClientCert [b64encode [SSL::cert 0]]
I have configured the SSL Client, and configured my virutal server to use the iRule resouce. However, when I get to the web page and look at the source, I do not see client certificate.
Gordon
Hi Gordon,
There’s a known issue with the SSL::cert values not traversing the events as expected.
To work around this problem, you’ll need to save the cert into the session table in the CLIENTSSL_CLIENTCERT event, then retrieve it in the HTTP_REQUEST event, as in these posts:
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&forumid=5&postid=13968 (Click here)
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&view=topic&postid=13667 (Click here)
(I believe that the encoding and header/footer manipulation requirements will depend on the type of certificate presented.)
HTH
/deb
