I have recently upgraded the IOS to 11.1.0 now I was trying to upload the hot-fixes using the GUI but it gives error every time… what is the problem is the hot-fix uploaded in some other way ??? can any one tell me where may the problem be??
no i didnt tried this but if the IOS is getting uploaded using the GUI what is the problem with hot-fix is it a limitation that the hot fix can not be applied via GUI…
The hot-fix import through web gui is giving continuous error, I thought may be its the problem of the downloaded file so i tried downloading it again 2 times but once i try to import the downloaded package in the middle the error message comes up… how to manage this now… ??? any idea…
I have tried it using the Firefox 9.0.1 let me try it with another web browser to be sure if the problem is from browser platform, can you refer me to any of the document that I may use to do the same using the command line.
Now when I have up loaded the Hot-fix using the web browser and I want to install it in the volum drop down list it does not show the current volume which is active in which the IOS VER11.1.0 is running??? so is it ok to install this hot-fix in some other volume??? or do I have to boot to another IOS and then do this upgrade using the WEB UI coz when I boot to other IOS the volume where Ver 11.1.0 is installed becomes avaliable in the list. Now I also want to know how about the OPSWAT and else hot-fix when i upload it i dont see it in the list, why is that is it getting installed directly or there is some problem with it… ??? can you reply to this… please…
v10/v11 hotfix is not able to install in current active boot location. you have to install to another boot location or switchboot to another boot location before.
so if i install the hot fix for IOS version 11.1.0 on another boot volume that is not a problem at all ??? correct??? the cumulative hot fix appears under the hotfix tab how abt the other updates like OPSWAT and Geoloaction fixes when they are uploaded they dont show up under the hotfix tab it seems like they are getting installed directly ??? are they not going to show up under the Hot fix tab or there is something wrong in my setup and it should appear under the tab of hotfixes once uploaded…???
