Is 172.30.140.42 the correct IP for the peer self IP address? Do you have port lockdown on that self IP set to one of these: allow 443, allow default or allow all?
You can run csTest.pl to get help troubleshooting this:
In some F5 manual i saw that, For Active/Active mode, we have to set the default routes of our backend servers, to the floating IP address of either unit1 or unit2.
I have not created routs with these IPs anywhere.
Can that be the cause of the problem?
Can you please tell how to configure these routes.
curl -k https://172.30.140.42 BIG-IP®- Redirect // Hide error message container if browser supports javascript and web s tandards if (document.getElementById) { document.write(‘’) document.write(‘content { display: none; }’) document.write(‘’) } // Redirect user to start page when window loads window.onload = function() { location.href = ‘/xui/?content=/tmui/tmui/system/settings/redire ct.jsp’ } if (document.getElementById) { document.write(‘Redirect…’) } JavaSc ript not enabled / supported This configuration utility requires JavaScript in order to f unction properly. If your browser supports JavaScript, check your "Options& quot; or “Preferences” section to enable this feature. Browse r does not suport basic W3C standards This configuration utility has been designed to work with we b browsers that support standards created by the Wo rld Wide Web Consortium (W3C). The web browser you are using does not suppor t these standards, and therefore will not operate properly with this configurati on utility. To learn more about W3C standards and compatible web browsers, pleas e visit http://www.webstandards.or g/upgrade. [root@TMHRED123:Active] config
I’m running two virtual LTM’s in ubuntu 8.10 OS in Active/Standby mode. I’m not able to sync the config from active to standby and wise versa and the error message given below:
Loading the configuration:
/sbin/restorecon: Error while labeling files under /var/ts
