private key and intermediate certificate
Hi I received the Root certificate and the intermediate certificate but when i try to create SSL profile it asks me about the key can anyone help, please?
hI,
Please let me know from where you create CSR file? If you created CSR file from F5 key will be available already. if CSR is created from server etc.. then you need to ask key from respective teams.
Hope this helps.
hI,
Hope this helps.
I imported from F5
I imported from F5
the new certificate which I have is wildcert
You generated CSR file from F5?
yes
yes
can I use the old key?
You have to create a certificate chain using the intermediate certificates.
Add your wildcard certificate, private key and chain in the ssl profile (client).
Cheers,
Kees
you cannot use old key
You have to use the key that has been generated when the csr was created.
When you import the certificate (by clicking on the csr) the BIG-IP will combine them in the webgui.
To create sslprofile I should have certificate,key and chain so I choosed the root and old private key then the intermediate they provided me with root certificate and the intermediate certificate without the private key so because of this i am using the old private key which exist on F5
