Hi Guys,
I have four servers set in priority 100,90,50 and 40. Problem is, during testing when attempting to back to the server with the priority 100, it doesn’t failback automatically, I have to manually fail the server the server to make it go back to the main server.
I tried using some iRules, but I can’t seem to get them to work. The closest one was this simple one.
when CLIENT_ACCEPTED { persist uie 1 }
That came from this link:Single Node Persistence
The only problem with that was it was persistent on the wrong node.
Is there anyway I could use that iRule and maybe add some commands so that the server that is active with the highest priority be the server that gets the traffic?
Thanks.
