Prevent three way handshake on VIP when nodes unavailable
Very simple setup VIP and pool, if all nodes are unavailable (failed health check) we don’t want the VIP to respond on a three-way handshake … which it does by default due to the full-proxy feature of the big-ip.
Tech support advised an irule to discard the connection which made it worse:
when CLIENT_ACCEPTED {
if { [active_members VIP-vh9stage.nml.com_71.164_80] == 0 } {
discard
so i changed it to a reject which is better, but still doesn’t prevent the 3-way. After all, it is when the client is accepted.
Oddly enough, when I tested on 9.4, I think ‘discard’ also triggered a reset (!?).
I believe that when you add a TCP profile to a virtual server, there is no way to prevent TMM from completing a three way handshake.
Check this post from rapmaster_c for more info (Click here).
Aaron
