Preserve old cookie expire Irule
Hi, I have an Irule to remove old cookie and insert a new cookie and value. The dev team change the aplication and insert the expire age in old cookie. How I preserve this atribute in new cookie? Follow my Irule:
when HTTP_RESPONSE { set cookies [HTTP::cookie names] look for a persistence cookie being set if { $cookies contains “JSESSIONID” } { rewrites all cookies being set foreach cookie_name $cookies { set cookie_value [HTTP::cookie $cookie_name] HTTP::cookie remove $cookie_name HTTP::cookie insert name $cookie_name value $cookie_value domain “.mysite.com.ar” path “/” } } }
Thanks!
Based on your iRule need to add the expire but needs to be an additional command.
    if { $cookies contains "JSESSIONID" } {
            set cookie_expire [HTTP::cookie expires $cookie_name]
            HTTP::cookie insert name $cookie_name value $cookie_value domain ".mysite.com.ar" path "/" version 0
            HTTP::cookie expires $cookie_name $cookie_expire absolute
However your iRule is replacing each cookie with the same cookie name and value, you can simple update the domain and path instead of remove and replace, this should not change the expires value set by the backend server:
            HTTP::cookie domain $cookie_name ".mysite.com.ar"
            HTTP::cookie path $cookie_name "/"
