how can I check the current power consumption on F5 devices?
not sure you can, don’t know many devices that report this to be honest, easiest would be a power meter between the f5 and power socket.
Thanks boneyard, i searched a lot iy seems there is no any othet way
1 - If you have a UPS with SNMP management, plug just the F5 device into it and read the draw using a MIB browser or network management app. 2 - Plug the F5 device into a managed PDU and read the draw, power factor, etc off that.
