Ok, I’ll admit that I’m probably just not looking in the right spot, but does anyone know where to find documentation on setting up the PostgreSQL monitor? I’ve been able to get a simple HTTP monitor up and running, but that only tells me the status of IIS. I also need the status of PostgreSQL and it looks easy enough to do but I can’t figure it out.
Ok,
Got one step further. I’m able to monitor PostgreSQL & IIS seperately for the same pool. Next question is, how do I setup one node to be down if both IIS & PostgreSQL are not both up?
Hi Shaun,
To create a dependence, you can configure an alias port for the custom HTTP and postgresql monitors and then assign both monitors to both pools.
Aaron
