I’m running into the exact issue described in F5 release notes starting with 11.2.1 - BIG-IP APM 11.2.1 see article 340549
"The rewrite plugin does not implement forwarding HTTPS requests through the HTTPS proxy correctly. However, forwarding HTTP requests through the HTTP proxy does work correctly.
To work around this problem, create a layered virtual server to catch HTTPS traffic leaving APM and forward it to a HTTPS proxy server using CONNECT. Proxy authentication is not implemented, and if response status from HTTPS proxy server is not 200, then use an iRule to close the connection."
I’m just not sure about what is meant/how to implement. Could anyone possibly shed some light?
Thanks!
