port redirection without using irule
when application users targets old infra pointing to x.x.y.y:6009 and we need them to be redirected to z.z.x.y:10108 without using iRULE.
is there a way to do it?
Please advise.
why without using irule???
you can do it with with Local traffic policies (since version 11.4) or HTTP Class (up to version 11.3)
Stanislas
can you please provide an example?
Thanks in advance.
what we require is that everything in the URL remains same except the port
Thanks in advance.
  1. can you please answer my question: why without using irule?
  2. I proposed 2 solutions based on version… which version is installed?
  3. can you explain what you mean by “redirect”? do you mean HTTP redirect or pool member with port different than virtual server?
  4. Alteon is not the best nickname on a F5 forum :slight_smile:
Hi Stanislas,
version details Product BIG-IP VE Version 11.3.0
so the requirement is x.x.y.y:6009/abc/def/login.aspx and we need them to be redirected to z.z.x.y:10108//abc/def/login.aspx.
so there is existing vip with pool members (a.b.c.d:10108 and e.f.g.h.i:10108)
need to get syntax across using TCL or regex to achieve this..
Hi alteon,
you can create a HTTP Class (Profile / Protocol / HTTP Class) with:
