Port range iRule
We have a requirement for a wildcard virtual server and to allow access to the application servers on port range between 30000 and 32768.
When I apply the below iRule, I’m unable to reach the servers.
when CLIENT_ACCEPTED {
if { {expr [TCP::client_port] < 30000] or [expr [TCP::client_port] > 32768} } {
  reject
I’m getting client resets on the pool members when the iRule is applied.
192.168.20.142.53464 > 10.18.142.64.31090: Flags [S], cksum 0xe5ad (incorrect -> 0x12c3), seq 371331784, win 4380, options [mss 1460,nop,nop,TS val 3830442533 ecr 0,sackOK,eol], length 0 out slot1/tmm0 lis=/Common/applicationname-any-vs
17:47:16.391284 IP (tos 0x0, ttl 62, id 26705, offset 0, flags [DF], proto TCP (6), length 40)
10.18.142.64.31090 > 192.168.20.142.53464: Flags [R.], cksum 0x571b (correct), seq 0, ack 371331785, win 0, length 0 in slot1/tmm0 lis=/Common/applicationname-any-vs
As soon as the iRule is removed, traffic connects successfully.
Hi Zuke,
the
if
command has a build inmplicit expression. No need for the explicit
[expr]
command.
    if { ( [TCP::client_port] < 30000 ) or ( [TCP::client_port] > 32768 ) } then {
        reject
Just for learning purposes the iRules below will work too. But they are more complex and also slower, since you basically pipe the output of the explicit
[expr]
command (0 or 1) to the implicit expression of the
if
command…
    if { [expr { [TCP::client_port] < 30000 }] or [expr { [TCP::client_port] > 32768 }]} then {
        reject
    if { [expr { ( [TCP::client_port] < 30000 ) or ( [TCP::client_port] > 32768 ) }] } then {
        reject
Cheers, Kai
In this context,
TCP::client_port
refers to the ephemeral port that the client system uses to connect to the virtual server. To specify the virtual server’s port range, use
TCP::local_port
instead. Also, “then” is redundant and may cause an error.
    if { ( [TCP::local_port] < 30000 ) or ( [TCP::local_port] > 32768 ) } {
        reject
