port pass through...
This may be simple and I am sorry if it is. I always setup my vips as a hostname and IP for each service and then they pass through to a certain port. I have a request to pass through the same URL to different ports based on the port in the URL. So say you have www.joe.new.test:8080 that goes to port 8080 on the server and www.joe.net.test:8443 goes to port 8443 on the same server. Can you do this with the same VIP and pool? Also a similar question if you have a URL like www.joe.test/portal would go to one pool and www.joe.test/ws would go to a different pool. Can you do that? So that basically everything comes in as one URL with a different URI for each pool (application.) Thanks in advance and sorry if this is a stupid question… Thanks Joe
Hi Joe,
If you create a VS and pool members on port 0, LTM will not translate the port. So whatever port the client requests will be used to load balance to the pool. If you want to break out specific port 80 URIs, you could create another VS on port 80 and use HTTP classes or an iRule to select a pool based on the requested URI. If you wanted to do this for HTTPS traffic, you could create a VS on port 443 and decrypt the SSL with with a clientssl profile. You could then use HTTP classes or an iRule to select a pool based on the requested URI. The pool members would normally be defined on port 80 and you’d need to enable port translation on this VS.
To use HTTP classes to select a pool member based on URI, you can create one class per pool. Then configure the URI/path filters using string patterns like /portal* for the /portal requests and /ws* for /ws requests. To use an iRule to do the same thing, you could use a switch statement:
http://devcentral.f5.com/wiki/default.aspx/iRules/switch
If you want more detailed steps for implementing this, let us know which methods you think you’d like to use.
Aaron
Hoolio, first sorry about the double post. Not sure how that happened or how to delete it. OK, so I want to do it with HTTP classes. I am running version 9.3.1 and it doesn’t seem as easy as the URL that you sent says. The only place I can see to specify a URI is in compression? Is that the right place? Then how do you tell it to send the request to a certain pool? I see in the VS where you can select the http profile but then what? Doesn’t give you a choice between one pool or another? Thanks Joe
Hi Joe,
No worries about the double post. HTTP classes were added for ASM-licensed units in 9.2 but not for LTM-only licensed units until 9.4. You’re seeing the HTTP profile--not HTTP class profile. So for LTM version 9.3, you’ll need to use an iRule. You can try something like this for the port specific HTTP or HTTPS VS(s):
    Check the requested URI with wildcards
   switch [HTTP::uri] {
      "/ws*" {
         pool ws_pool
      "/portal*" {
         pool _pool
      default {
         pool default_pool
Aaron
Thank you very much. As a follow up question, how hard is it to upgrade a failover pair of LBs without any downtime?
Joe
There will be at least a momentary outage when you fail over between units. The process is described in SOL11215:
SOL11215: Upgrading an active/standby BIG-IP high availability pair
Aaron
Thank you as always!
Joe
Hoolio,
Thank you very much, with a little tweaking I was able to get this to do exactly what I want. Now I need to look into upgrading so I can try it with the http class.
Joe
Posted By hoolio on 07/15/2010 01:07 PM
Aaron
While true, this is usually only a loss of a few packets at the network level (in reference to hardwire failover). With unmirrored short-lived connection or mirrored long-lived connections, TCP handles this failure with aplomb and most nrt applications don’t even notice. With rt applications you might see a miniscule screen freeze or some minor audio/video corruption.
