p
Can you describe what you tried to do please, it should be pretty simple. I assume this is a physical appliance?
p
OK, so you’ve configured 1.4 as the destination and 1.3 as the source in the Configuration Utility GUI? What have you attached to 1.4 to capture the mirrored data?
i t
You should be able to upload them here; if you edit your post there’s an option for ‘attachments’ at the bottom.
If it’s too trick, send em through to steve @ iveson.eu (removing the spaces)
i attachet them in my first post can u check if it is okey
Can’t see them.
i think that now they are available plz check them
OK I’ve seen them, thanks. So, the configuration looks just fine and I think perhaps you are expecting a bit too much from this feature? Traffic seen on interface 1.3 will be mirrored (and only mirrored) to 1.4. If 1.3 goes down, no traffic is mirrored. This feature doesn’t allow 1.4 to act as a backup to 1.3. 1.4 will not assume 1.3s role and IP etc. This feature just copies traffic seen on 1.3 to 1.4 so you can capture it or send it to an IPDS or something similar.
If you want interface redundancy I’d suggest you configure a LACP trunk to cover you at L2 and (assuming you have two devices) network failover for L3/4.
ok 10x a lot for ur helping
best regards
You’re welcome, if you need any help with other features, just start another post. Cheers
