I am new to the iRules , i need to write an iRule that will apply to a VS and will accept only TCP connection from a specific range of destination TCP ports .
Can someone suggest such an iRule ?
You should have checked the wiki it would have give you what you need
when CLIENT_ACCEPTED {
if { not([IP::addr [IP::client_addr]/16 equals "10.10.0.0"]) } {
reject
If you’re trying to allow access to specific ports on an any port VIP, you could check the TCP::local_port value (Click here) to make a decision:
This event is triggered when a TCP connection is established between the client and the VIP
Check if the port is between 1001 and 1999
if {not ([TCP::local_port] > 1000 and [TCP::local_port] < 2000)}{
Log a debug message that we're resetting the TCP connection.
log local0. "[IP::client_addr]:[TCP::client_port]: Request to illegal port: [IP::local_addr]:[TCP::local_port]"
Send TCP reset
reject
Aaron
