Hello,
i have done port forwarding for SMTP traffic. for this I have configured VIP on port 25 and pool members of this VIP on port 2500.
however when i test i get this TWO below diff results.
1. ON DIRECT NODE :
$ telnet 10.155.63.126 2500
Trying 10.155.63.126…
Connected to A92SV00699JIV (10.155.63.126).
Escape character is ‘^]’.
220 localhost ESMTP SubEthaSMTP
HELO domain
250 localhost
QUIT
221 Bye
Connection closed by foreign host.
2. VIA VIP :
$ telnet 10.155.65.43 25
Trying 10.155.65.43…
Connected to uat.my.saint-gobain.com (10.155.65.43).
-------------- here “220 localhost ESMTP SubEthaSMTP” is missing !!!
HELO domain
250 localhost
QUIT
-------------- here no reaction/resonse from the node
can anyone please help?
2. VIA VIP :
HELO domain
250 localhost
QUIT
-------------- here no reaction/resonse from the node is 220 not a line below HELO domain??
this is my testing.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.79:25
ip protocol 6
[root@ve10:Active] config telnet 172.28.19.79 25
Trying 172.28.19.79...
Connected to 172.28.19.79 (172.28.19.79).
Escape character is '^]'.
220 mail.f5.com ESMTP
HELO me
250 mail.f5.com
QUIT
221 mail.f5.com
Hi Nitass
if you see both outputs you can find difference in sequence.
220 should be above HELO domain.
after QUIT command 221 sequence of aborting is missing.
220 should be above HELO domain. sorry i might misunderstand i.e. i thought you typed HELO too fast.
e.g.
HELO me
250 mail.f5.com
anyway, if it is not, is there any special setting in the virtual server configuration?
This is the current setting I have on F5.
[root@STG1F5LDB01:Active] config b virtual vs_jive_uat_25 list
virtual vs_jive_uat_25 {
snat automap
pool pool_jive_uat_25
destination 10.155.65.43:smtp
ip protocol tcp
profiles {
http {}
tcp {}
vlans INTERCO enable
[root@STG1F5LDB01:Active] config b pool pool_jive_uat_25 list
pool pool_jive_uat_25 {
members {
10.155.63.126:rtsserv {
priority 5
10.155.63.153:rtsserv {
priority 1
session user disabled
nitass
July 10, 2012, 8:31am
6
why do you use http profile for smtp traffic? does it really work??
I tried removing HTTP profile.
snat automap
ip protocol tcp
and after this, when i tested, connection drops immediately.
Can you tell me tcpdump command to display capture during test? I want to test connection on VIP.
i tried below and did not had anything in capture.
[root@STG1F5LDB01:Active] config tcpdump -s0 dst 10.155.65.43 and dst port 25
tcpdump: WARNING: eth0: no IPv4 address assigned
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
0 packets captured
10 packets received by filter
0 packets dropped by kernel
nitass
July 10, 2012, 10:01am
8
Can you tell me tcpdump command to display capture during test? I want to test connection on VIP. can you try this?
to screen
tcpdump -nni 0.0 \(host 10.155.65.43 and port 25\) or \(host 10.155.63.126 or host 10.155.63.153 and port 2500\)
to file
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap \(host 10.155.65.43 and port 25\) or \(host 10.155.63.126 or host 10.155.63.153 and port 2500\)
Thanks Nitass, but issue is resolved now..after removing http profile.
