Dear Geeks,
Although i am very much confortable with GUI. Please share me the useful CLI commands also…
Dear Geeks,
Bigpipe Mappings
Bigpipe Mappings
nitass thanks…its showing me the bigpipe & tmsh commands…whats is the differences between them…
bigpipe is old command. it is no longer available in 11.x. tmsh is the new one.
ohhhk…thanks for clarifying this…
It does not show me the commands used for certificate checking like…---> Curl -v . Please reply.
you may try searching “openssl s_client” and “curl” commands.
ok..So you mean that i need to search the commands on the link you suggested above…right??
no, i mean Google. ![]()
yah got it…thanks for the help provided…
