PoolMember.set_session_enabled_state fails and return null(0), while it should exit with no return value nor errors.
iControl fails when I call PoolMember.set_session_enabled_state and return null(0) It occurs at the last step of following API calls.
(Each line stands for an API call)
LocalLB.Pool.remove_monitor_association (LocalLB.Monitor.delete_template) LocalLB.VirtualServer.set_default_pool_name LocalLB.Pool.delete_pool
LocalLB.NodeAddressV2.delete_node_address (this call is skipped due to the node is being used by somewhere else)
LocalLB.VirtualServer.remove_persistence_profile
LocalLB.ProfilePersistence.delete_profile
LocalLB.VirtualServer.remove_rule
LocalLB.Rule.delete_rule
LocalLB.VirtualServer.delete_virtual_server
System.ConfigSync.save_configuration
System/ConfigSync.synchronize_configuration
LocalLB.VirtualServer.create
LocalLB.VirtualServer.set_default_pool_name (setting up default pool as “”)
LocalLB.Pool.delete_pool (deleting dummy pool)
LocalLB.VirtualServer.set_enabled_state LocalLB.VirtualServer.add_profile (adding SSL profile)
LocalLB.NodeAddressV2.create
LocalLB.Pool.create
LocalLB/Pool.add_member
LocalLB.PoolMember.set_connection_limit
LocalLB.PoolMember.set_session_enabled_state (<--- Error occurs at here)
The API call above fails then returns null(0)
App versions BIG-IP 11.2.1 Build 1217.23 Engineering Hotfix HF9 iControl 11.2
