Hello,
I use Failsafe Gateway. I see that the pool on the unit 2 ( inactive unit) is on state unchecked but monitors are up (gateway_imp). I do not know how to make this pool on unit 2 on active state.
Does anyone have an idea ?
Thanks a lot,
Regards,
Flo,
Name FAILOVER-DMZ
Availability Unknown (Enabled) - The children pool member(s) either don’t have service checking enabled, or service check results are not available yet
POOL FAILOVER-DMZ LB METHOD round robin MIN/CUR ACTIVE MEMBERS: 0/0
| conns (cur, max, limit, tot) = (0, 0, 0, 0)
| (pkts,bits) in = (0, 0), out = (0, 0)
±> POOL MEMBER FAILOVER-DMZ/10.2.2.2:any ACTIVE,UNCHECKED SESSIONS ENABLED
| requests (total) = 0
