If you force the bigip offline the floating IP does not respond. What will be the status be of the pools during the time the device is “offline”? Will the health checks still be active?
Michael, this depends on version. See the following sol for the change in behaviour: K17252: The bigd process no longer sends monitor traffic to pool members when the BIG-IP system is offline or a VIPRION blade is disabled
In short, in later versions the health checks are suspended.
Hope this helps,
N
Thank you!
No probs
