Pool statistics current connections
What’s considered a current connection? We have four nodes in a pool and have it set to round robin but it seems to not spread the connections around. We will have a node with 100 connections and the other three have as little as 10 to 15. What’s considered a connection? How do we make sure we get these connections spread across the nodes evenly?
Hello,
“Current Connection” corresponds to all opened connections (socket) between the F5 and Pool Member.
There are many factors that can explain why you don’t have even connection between pool members.
I recommend you to read the following article and determine why you have this behavior.
Hope it helps,
Regards
