I need help understanding and resolving why my iRule that uses a data group is only working for 2 out of the three addresses in the group. My current configuration is a standard VIP listening on port 80 using a HTTP and One Connect profile along with SNAT. This VIP has three iRules assigned to it that do various redirects with the one in question using a data group to identify 3 IP addresses that connect to us and redirect them to a different pool of servers. The iRule looks like this:
when CLIENT_ACCEPTED { If remote IP address matches the datagroup then select new pool if { [class match [IP::remote_addr] equals data.group.com] } { pool new server.pool.com-pool If remote IP address doesn’t match datagroup default to VIP pool } else { pool existing.server.pool } }
This is working for two of the 3 IP addresses in the data group. The one is still being directed to the existing server pool. I have double and triple checked everything and do not understand this behavior. Any help would be greatly appreciated.
pool server.pool.com-pool
If remote IP address doesn't match datagroup default to VIP pool
The typo only existed in the post and not on the production iRule. I have fixed it below to reflect properly. I wasn’t trying to use new as a command.
when CLIENT_ACCEPTED { If remote IP address matches the datagroup then select new pool if { [class match [IP::remote_addr] equals data.group.com] } { pool newserver.pool.com-pool If remote IP address doesn’t match datagroup default to VIP pool } else { pool existing.server.pool } }
Ok then your iRule looks good. You need to turn on logging to see what IP::remote_addr is actually giving you and please post an example of one line in your datagroup.
log local0. "Remote address is [IP::remote_addr]"
Everything you have done is spot on so there is nothing wrong with your iRule. My only suggestion is watch IP addresses coming in. Quite often expectations don’t meet reality about incoming data. Logging is your source of truth.
You mentioned 3 iRules. What are the other two doing? Could there be some conflicting logic? This iRule is fired early in the http connection (CLIENT_ACCEPTED event). As there is no escape (return) in this iRule, the connection flow continues and next event is HTTP_REQUEST and so on. So the other iRules may/will fire, too.
