Is there a way (on LTM 10.2.3) to have a VIP with default pool containing couple of VIPs in it? Need to test if there’re no active members in the pool, that VIP will be taken down by main VIP’s monitor. Does that make sense?
You can’t have a VS as a pool member. But you could add more actual servers to a single pool, use an iRule to select among multiple pools or use an iRule to select among multiple virtuals (using the virtual command).
Here’s what I have: an iRule which redirects traffic to either default or login pool based on the uri. If no members are available in the selected pool, an error page is displayed (not good since second DC might still be available).
Here’s what I want to have: somehow detect (maybe it should be done on GTM layer) that both pools are down, and send traffic to another Data Center. I thought of having one pool per VIP, and have a VIP as a pool member. This way, if no members are active, the VIP should be marked down before it’s requested, and LTM or GTM would route traffic to another VIP in second DC. If second DC has the same condition (nothing available), then an error page should be displayed.
Couldn’t you use an HTTP monitor on GTM and have an iRule on the LTM virtual server which sends a reset (or HTTP response which the GTM would consider a failure) back if both the login and default pools are down?
We do have a GTM monitor, but it still happens (maybe due to latency) we forward traffic to LTM with no available pool members. Will sending a “reset command” from one LTM to GTM be enough to take that LTM out of mix and forward to another LTM? Won’t I have a racing condition going from LTM to LTM?
Also, in case nothing is available in both DC, I still want to display error message. Maybe, I need to pass some header var (“LTM failed”) from failed LTM? This way, if I receive it and no members are available, I then display an error message?
