Pool members not taking traffic
Team,
Please help with a reason to understand the failure of taking traffic by a pool member. i have a Virtual Server with a two pool members and i see one of the pool member is not taking traffic which was taking earlier. what could be a possible reason that a pool member wont take traffic ? i use round robin and ratio as 1:1. please suggest.
Thanks swap
when did it stop taking traffic? what happened?
it stopped taking traffic all of sudden? not sure why so.
Which BIGIP version are you using? Are you using oneconnect? HTTP profile? Persistence? What your persistence table is saying about it?
When you say “not taking traffic”, do you mean a health check is marking the member is available and any connections sent to the member fail? or do you mean no connections are being sent to the member? What health monitoring are you performing on the members?
