Hi guys,
I’m searching way to manage pool members via SNMP (OID) in F5 LTM 1600. All what I need is enable or disable pool member.
Is it possible? Did someone tried to manage pool members?
Hi guys,
Hi Max
I’m not sure about SNMPSET but you can do that with IControl. Check devcentral for many scripts
it seems to be read-only. mine is 11.4.0.
ltmPoolMbrStatusEnabledState OBJECT-TYPE
SYNTAX INTEGER {
none(0),
enabled(1),
disabled(2),
disabledbyparent(3)
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The activity status of the specified pool member, as specified
by the user."
::= { ltmPoolMbrStatusEntry 6 }
this is write-only but deprecated. anyway, i tested but got notWritable error.
ltmPoolMemberNewSessionEnable OBJECT-TYPE
SYNTAX INTEGER {
user-disabled(1),
user-enabled(2),
monitor-enabled(3),
monitor-disabled(4)
MAX-ACCESS write-only
STATUS deprecated
DESCRIPTION
"Deprecated!
This field is not interested to user through SNMP interface
Whether a new session can be enabled or not for the specified pool member."
::= { ltmPoolMemberEntry 12 }
[root@ve11a:Active:Not All Devices Synced] config snmpset -v 2c -c private localhost .1.3.6.1.4.1.3375.2.2.5.3.2.1.12.11.47.67.111.109.109.111.110.47.102.111.111.23.47.67.111.109.109.111.110.47.50.48.48.46.50.48.48.46.50.48.48.46.49.48.49.80 i 1
Error in packet.
Reason: notWritable (That object does not support modification)
Failed object: F5-BIGIP-LOCAL-MIB::ltmPoolMemberNewSessionEnable."/Common/foo"."/Common/200.200.200.101".80
