My pools members are still showing as available even when the monitor should be failing. I first had it just look for 200 OK and it wasn’t working so added 403 as a disable string and it still doesn’t work. Am I missing something or is this a bug?
Ltm::Pool Member: dcentral821-443 10.16.130.165:443
Status
Availability : available
State : enabled
Reason : Pool member is available
ltm pool dcentral821-443 {
members {
10.16.130.164:https {
session monitor-enabled
10.16.130.165:https {
monitor dcentral821-443
ltm monitor https dcentral821-443 {
cipherlist “DEFAULT:+SHA:+3DES:+kEDH”
compatibility “enabled”
defaults-from https
destination *:*
interval 5
recv “200 OK”
recv-disable “403”
send “GET /wsp/httpStatus.jsp HTTP/1.1\r\nHost: dcentral821.intra.aexp.com\r\n\r\n\r\n”
time-until-up 0
timeout 16
curl -kI https://10.16.130.165/wsp/httpStatus.jsp
HTTP/1.1 403 Forbidden
Date: Fri, 14 Dec 2012 23:07:03 GMT
Server: IBM_HTTP_Server
$WSEP:
Set-Cookie: JSESSIONID=00002Sq11SBcG6Nb-dKSFLk-GWh:17b9prvpt; Path=/
Expires: Thu, 01 Dec 1994 16:00:00 GMT
Cache-Control: no-cache=“set-cookie, set-cookie2”
Content-Type: text/html;charset=ISO-8859-1
Content-Language: en-US
