Pool member has been marked down by a monitor
Hi I am new to F5..Trying to learn. During configuration I found following problem, “Pool member has been marked down by a monitor”. What does it mean? problem in monitor profile?
it’s not necessarily a problem with the F5 - this message indicates that the pool member is currently failing the assigned monitor. If the monitor assigned to the pool is, for example, a TCP monitor, then the F5 is unable to connect to the pool member on the pool member’s associated TCP port.
Then do I need to change monitor? I have added https monitor..
it depends on the type of server/service that you are monitoring. if the pool member is hosting an HTTPS site to which the F5 is forwarding traffic, then it should be an HTTPS monitor. Check out: 404 Page not found | BIG-IP Documentation 404 Page not found | BIG-IP Documentation
