pool member forced offline
I want to use icontrol to force a pool member offline. When I set a pool member “forced offline” from the GUI, the audit log shows:
POOL_MEMBER modified:
pool_name=“Acme_ONLINE_PRE-PROD_POOL”
addr=10.178.123.131
port=123
monitor_state=7
new_session_enable=0
monitor_rule=“”
update_status=1
In the SDK, it seems as though monitor_state=7 is not an option for poolmember set_monitor_state - only 0 & 2 (STATE_DISABLED & STATE_ENABLED).
Where should I be looking for this?
Since we use IP affinity persistence, the connections never drop off to zero, because there are many users behind proxies. Is there a way to put a member “Forced Offline (Only active connections allowed)”, as opposed to “Disabled (Only persistent or active connections allowed)”?
I see where my mistake was. I was using LocalLBPoolMemberMemberSessionState. What I really wanted was LocalLBPoolMemberMemberMonitorState.
