Your question would need more details to correctly answer. To wrap my head around the "selfs’ and “float” i like to think of them this way:
The selfs IP belongs to an INDIVIDUAL f5 and provide layer2 adjacency to the vlan segment. As an exampled, If you have a HA pair (or cluster), the self -is what is used to allow traffic in/out of each one as a unique entitiy.
If a “float” is configured - it moves from f5-HA-pair1 to f5-HA-pair2 in the event of a failover. This is a sepeate IP that floats/ moves from one appiance to another .
As you define the virtual server, there will be a configuration item of “Source Address translation” - or as i think of it “After the f5 sends the packet to the server, how does it reply back to the f5”. The configuration options are:
None: If this is configured, the f5 must be either the default gateway for the server directly - or possible the default gateway for the network segment (routing table). The backend server get the packet and reply to the sender directly - and f5 sees the packet in and out.
Automap: This tells the f5 to change the “source address” of the packet as it send it to the backend server, thusly the backend server reply to the f5 regardless of the routing that might be in place. When Automap is used, the f5 will pick either its default route or if defined ,a self address / range that provides a more specific route to the backend server.
SNAT: If defined - also changes the source address of the packet as it sends it to the backend server. This allows you to specify one or more IP addresses for the backend server to reply to.
From the CLI - from bash you can run ’ ip route ’ to see what the routing config looks like. And you can run ’ ip route get IP.ADD.RE.SS ’ to find which of the route would be used if you are sending traffic to that IP, you can test both inbound to the f5 - vip --- and outbound to the backend server pool memember. *- route domains if configured might effect this.
If you only have 1 self, this will be the source of all the f5 monitors going back to the pool members. If you have more then 1 self, it will pick the most specific to the route and follow the table provided with ip route. If you have a float that is most specific the float will be used for data packets - and the self will be used for monitor packets IF source address translation is enabled, if not enabled - it follow the network routing table for in and outbound.
I’ve take some techincal liberties with this, but i think you will be able to use this and find your answer - or ask a diffrent question with the details you find.
