I was using a Health Monitor as below.
monitor sap-http-55000 { defaults from http interval 30 timeout 91 dest *:55000 recv disable “Dispatcher running but no server connected!” recv “^HTTP/1.1\s(400)” send “GET /irj/portal/ HTTP/1.1 \r\nHost:x.x.xom\r\nConnection:close\r\n\r\n”
On HTTP response 400 Bad request in F5, client can access the URL and it gives successful log in and client is getting 200 OK in HTTP Watch tool in the client browser.
On HTTP 503 status " Not ready", we are getting the node member as disabled but still the pool is showing in up status (Green)
- > GET /irj/portal HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 10.85.183.22:55000 Accept: /
< HTTP/1.1 400 Bad Request < Content-Type: text/html; charset=UTF-8 < Set-Cookie: com.sap.engine.security.authentication.original_application_url=GETDbtBda6XdWhLSsdN3u5eHbHa%2B%2BZj2qgH6yIDRiB0%2Bv%2FJmRNvbWw08T%2F7aRadd4jVNqdPIqU8ynR5gQIzXHBxNKSJiYzYRVeQ2m3KILrlttBOHCT%2BC9flBMtcH6knKQcdMhtGDRjhrzSV19XwkXLbSynvmwd4xuqz;Path=/;HttpOnly < Transfer-Encoding: chunked < Content-Language: en-US < expires: 0 < Date: Wed, 15 Apr 2015 09:50:51 GMT < Set-Cookie: PortalAlias=portal; Path=/ < Set-Cookie: saplb_*=(J2EE501080800)501080850; Version=1; Path=/ < Set-Cookie: JSESSIONID=(J2EE501080800)ID1747982450DB3c7d00ce1d0e707eadb174217dc4fee4c2f11f07End; Version=1; Domain=10.85.183.22; Path=/
The monitor acted by disable the node (10.85.183.22) on HTTP response 503 Not Ready, not expected as per the recv disable string “Dispatcher running but no server connected!” .
About to connect() to 10.85.183.22 port 55000 Trying 10.85.183.19… connected Connected to 10.85.183.19 (10.85.183.22) port 55000
GET /irj/portal HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 10.85.183.22:55000 Accept: /
< HTTP/1.1 503 Not Ready < Connection: close < Server: SAP J2EE Engine
What could be the cause for this for pool is showing green and member is disabled ?
Appreciate you kind feedback on this !
