pool check numeric values
Hello Community,
I’m trying to determine what each numeric value means when checking a pool’s state.
ex)
3) iRule3->VS3:
if { ([active_members pool1] < 1) or ([active_members pool2] < 1) or ([active_members pool3] < 1) } {
pool pool6
pool pool3
What does the " < 1 " actually mean? What other numeric values are there and what do they mean?
Thanks in advance.
Regards,
TRX
The example you show is checking the number of active pool members so <1 would mean all of the pool members are down.
Would happen to know what the numbers below mean?
1, 2, 3, etc?
ex) Goal is to check if the pool member specified is flagged down/disabled or NOT
if { ([pool google-search member 192.168.254.189 80] < 1) } {
pool google-search member 167.3.11.93 7800
return
pool google-search member 167.3.10.93 7800
return
Thanks.
Regards,
TRX
If you want to check the status of a node you can use the LB::status command.
http://devcentral.f5.com/wiki/iRules.LB__status.ashx
Your iRule would look something like this:
log local0. "Node 1 Status:  [LB::status pool my.pool.name member 10.10.10.10 80]"
log local0. "Node 2 Status:  [LB::status pool my.pool.name member 20.20.20.20 80]"
if { [LB::status pool my.pool.name member 10.10.10.10 80] eq "down" } {
HTTP::redirect "http://www.yahoo.com"
if { [LB::status pool my.pool.name member 20.20.20.20 80] eq "down" } {
HTTP::redirect "http://www.msn.com"
Thanks! That works.
Regards,
TRX
