Hello everyone,
Having a tough time finding a correct answer to this. I have seen very similar answers but nothing that does quite what I am asking. I am new to iRules so be kind. I have a client with the following requirements.
- When connecting to abc.xyz flow is as normal.
- When connecting to abc.xyz/example they should be redirected to abc.external.org website while retaining the original URL that is locally hosted.
The external website is not hosted locally but is just an external resource the client has an association with. I have looked for an answer all weekend with no success other than being able to get the redirect to work properly.
What I have below is supposed to keep the original URL but it does not. It just does the redirect. Any help would be greatly appreciated.
if { [string tolower [HTTP::host]] equals "abc.xyz" and [string tolower [HTTP::uri]] starts with "/example" } {
HTTP::respond 301 noserver Location "abc.external.xyz"
I have also tried changing the HTTP::header on the HTTP_RESPONSE but that just gives me a 404 error with the following in the address bar “abc.xyz/abc.external.xyz”.
I have also seen suggestions of using rewrite profiles but that doesn’t seem to do what I want either and can’t find any real examples of them. Again, any help would be appreciated.
Thank you!
Jonathan
