i understand it adds Via header (e.g. Via: SIP/2.0/UDP 200.200.200.14:5060;branch=z9hG4bK-7941-4484-0f5;F5Tag=F5-Inserted-Header) to request and remove it (e.g. Via: SIP/2.0/UDP 200.200.200.14:5060;branch=z9hG4bK-7941-4484-0f5;F5Tag=F5-Inserted-Header, SIP/2.0/UDP 172.28.67.36:5060;branch=z9hG4bK-7941-4484-0) from response.
i use SIPp (http://sipp.sourceforge.net/index.html) as uac and uas. on uas, SIPp combines 2 Via headers together. so, when irule removes it, both are removed.
e.g.
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar-sip
ltm virtual bar-sip {
destination 172.28.20.16:5060
mask 255.255.255.255
pool foo-sip
profiles {
sip { }
udp { }
source 0.0.0.0/0
source-address-translation {
type automap
vlans-disabled
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo-sip
ltm pool foo-sip {
members {
200.200.200.101:5060 {
address 200.200.200.101
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
when SIP_REQUEST_SEND {
if { not ([SIP::via 0] contains "F5Tag=F5-Inserted-Header")}{
log local0. "Call-id : [SIP::call_id] Modified-sent :: From [IP::local_addr]/[UDP::local_port] To [IP::remote_addr]/[UDP::remote_port]"
SIP::header insert Via [format "SIP/2.0/UDP %s:%s;branch=%sf5;F5Tag=F5-Inserted-Header" [IP::local_addr] [UDP::local_port] [SIP::via branch 0]]
log local0. "Call-id : [SIP::call_id] Added-via :: [SIP::via 0]"
when SIP_RESPONSE {
if { [SIP::via 0] contains "F5Tag=F5-Inserted-Header"}{
log local0. "Call-id : [SIP::call_id] Modified-received :: From [IP::remote_addr]/[UDP::remote_port] To [IP::local_addr]/[UDP::local_port]"
if { [SIP::via 0] contains "[IP::local_addr]:[UDP::local_port]"}{
log local0. "Call-id : [SIP::call_id] Removed-via :: [SIP::via]"
SIP::header remove Via 0
/var/log/ltm
Jun 22 22:12:02 ve11a info tmm[8299]: Rule /Common/myrule : Call-id : 4484-7941@172.28.67.36 Modified-sent :: From 200.200.200.14/5060 To 200.200.200.101/5060
Jun 22 22:12:02 ve11a info tmm[8299]: Rule /Common/myrule : Call-id : 4484-7941@172.28.67.36 Added-via :: SIP/2.0/UDP 200.200.200.14:5060;branch=z9hG4bK-7941-4484-0f5;F5Tag=F5-Inserted-Header
Jun 22 22:12:02 ve11a info tmm[8299]: Rule /Common/myrule : Call-id : 4484-7941@172.28.67.36 Modified-received :: From 200.200.200.101/5060 To 200.200.200.14/5060
Jun 22 22:12:02 ve11a info tmm[8299]: Rule /Common/myrule : Call-id : 4484-7941@172.28.67.36 Removed-via :: SIP/2.0/UDP 200.200.200.14:5060;branch=z9hG4bK-7941-4484-0f5;F5Tag=F5-Inserted-Header, SIP/2.0/UDP 172.28.67.36:5060;branch=z9hG4bK-7941-4484-0
packet trace
pkt 2 and 3 are requests. pkt 2 is on client-side (uac and bigip). pkt 3 is on server-side (bigip and uas).
pkt 4 and 6 are response. pkt 4 is on server-side and pkt 6 is on client-side.
No. Time Delta Time Source Src port Destination Protocol Dst port Window BiF Vlan id Length Info
2 2013-06-22 22:12:02.004454 0.000000 172.28.19.251 5060 172.28.20.16 SIP/SDP 5060 4094 665 IN s1/tmm0 : Request: INVITE sip:service@172.28.20.16:5060, with session description
Frame 2: 665 bytes on wire (5320 bits), 665 bytes captured (5320 bits)
Ethernet II, Src: Force10N_d5:d4:47 (00:01:e8:d5:d4:47), Dst: Vmware_b3:1c:32 (00:50:56:b3:1c:32)
802.1Q Virtual LAN, PRI: 0, CFI: 0, ID: 4094
Internet Protocol Version 4, Src: 172.28.19.251 (172.28.19.251), Dst: 172.28.20.16 (172.28.20.16)
User Datagram Protocol, Src Port: 5060 (5060), Dst Port: 5060 (5060)
Session Initiation Protocol
Request-Line: INVITE sip:service@172.28.20.16:5060 SIP/2.0
Message Header
Via: SIP/2.0/UDP 172.28.67.36:5060;branch=z9hG4bK-7941-4484-0
To: service
Call-ID: 4484-7941@172.28.67.36
CSeq: 1 INVITE
Contact: sip:sipp@172.28.67.36:5060
Max-Forwards: 70
Subject: Performance Test
Content-Type: application/sdp
Content-Length: 136
Message Body
3 2013-06-22 22:12:02.004796 0.000342 200.200.200.14 5060 200.200.200.101 SIP/SDP 5060 4093 772 OUT s1/tmm0 : Request: INVITE sip:service@172.28.20.16:5060, with session description
Frame 3: 772 bytes on wire (6176 bits), 772 bytes captured (6176 bits)
Ethernet II, Src: Vmware_b3:1c:33 (00:50:56:b3:1c:33), Dst: Vmware_b3:01:0b (00:50:56:b3:01:0b)
802.1Q Virtual LAN, PRI: 0, CFI: 0, ID: 4093
Internet Protocol Version 4, Src: 200.200.200.14 (200.200.200.14), Dst: 200.200.200.101 (200.200.200.101)
Message Header
To: service
CSeq: 1 INVITE
Max-Forwards: 70
Content-Length: 136
Message Body
4 2013-06-22 22:12:02.006572 0.001776 200.200.200.101 5060 200.200.200.14 SIP 5060 4093 563 IN s1/tmm0 : Status: 180 Ringing
Frame 4: 563 bytes on wire (4504 bits), 563 bytes captured (4504 bits)
Ethernet II, Src: Vmware_b3:01:0b (00:50:56:b3:01:0b), Dst: Vmware_b3:1c:33 (00:50:56:b3:1c:33)
Internet Protocol Version 4, Src: 200.200.200.101 (200.200.200.101), Dst: 200.200.200.14 (200.200.200.14)
Status-Line: SIP/2.0 180 Ringing
Message Header
To: service ;tag=26498SIPpTag014484
CSeq: 1 INVITE
Contact:
Content-Length: 0
6 2013-06-22 22:12:02.006668 0.000087 172.28.20.16 5060 172.28.19.251 SIP 5060 4094 413 OUT s1/tmm0 : Status: 180 Ringing
Frame 6: 413 bytes on wire (3304 bits), 413 bytes captured (3304 bits)
Ethernet II, Src: Vmware_b3:1c:32 (00:50:56:b3:1c:32), Dst: Force10N_d5:d4:47 (00:01:e8:d5:d4:47)
Internet Protocol Version 4, Src: 172.28.20.16 (172.28.20.16), Dst: 172.28.19.251 (172.28.19.251)
Message Header
CSeq: 1 INVITE
Contact:
Content-Length: 0
