Please help me find the correct ISO file for upgrade
Hi Expert ,
We have LAB device and we would like to upgrade the ISO ., currently We are using BIG-IP v12.1.3.6 (Build 0.0.3) . Can you please help me find the correct file to upgrade this version . Preferably 15.1.3.1 0.0.18 .
Platform ID Z100
Platform Name BIG-IP Virtual Edition
Software Version BIG-IP v12.1.3.6 (Build 0.0.3)
BIG-IP, VE, LAB (IOOLGXS-LVFSKGB)
Hi  ,
Below is the path where said version iso file is available.
Also go through the supported BIG-IP upgrade paths given below before planning the upgrade.
Hope it helps!
There are 2 files with name 15.1.3.1 and 15.1.3.1_Virtual-Edition ..
Since I am looking for Virtual edition I should be searchning file in this path 15.1.3.1_Virtual-Edition .. ! Right ? But in that which file I have to use .
15.1.3.115.1.3Release07/19/202115.1.3.1 Release15.1.3.1_Virtual-Edition15.1.3Release07/19/2021Virtual-Edition
For upgrades, just use the 15.1.3.1 ISO. For new installations (deploy a virtual guest) use on of the images in the 15.1.3.1_Virtual-Edition directory.
