Please help in creating a content switching irule
Below is the requirement:- If url https://xyz.abc.com contains below switches ; it should point to pool1:-
/providerportal1/* - proxy to pool1 /Resources/* - proxy to pool1 /provider_get/* - proxy to pool1 /exadmin/* - proxy to pool1
else if url contains below switch;it should point to pool2
/portal/* - proxy to pool2
example :
1.https://xyz.abc.com/Resources/ >>>pool1 2.https://xyz.abc.com/exadmin/ >>>pool1 3.https://xyz.abc.com/portal/ >>>pool2
Give it a shot.
  if {[HTTP::host] == "xyz.abc.com"} {
    switch -glob [HTTP::uri] {
      "/providerportal1/*" -
      "/Resources/*" -
      "/provider_get/*" -
      "/exadmin/*" {
        pool pool1
      "/portal/*" {
        pool pool2
I would make a couple of minor changes for efficiency(HTTP::path rather than HTTP::uri), and to deal with the possibility of upper/lower case requests(string tolower):
  if {[string tolower[HTTP::host]]  == "xyz.abc.com"} {
    switch -glob [string tolower[HTTP::path]]  {
      "/resources/*" -
      "/provider_get/*" -
      "/exadmin/*" {
        pool pool1
      "/portal/*" {
        pool pool2
