I’m doing the mentioned PPTP thru BIGIP. Under the LSN pool list it says ‘MEMBER LIST’ Is this where the IP’s sit that I want the server to hand out to the clients? Example: we are on x.x.60.0/22 so is this the value that would go under member list (The IP’s I want clients to have)?
Can you clarify if you are using the CGNAT product module for BIG-IP or doing LSN with iRules in just LTM?
In the CGNAT module, the LSN pool would have a list of the IP’s that you want clients to get as their source address is changed on the way out.
Sorry. Yes I’m using the CGNAT. so the ‘members list’ is where those source IP’s would go, correct?
correct
correct
thanks a bunch!
thanks a bunch!
