Ping Federated Health Monitor
The Ping administrator gave me a URL to use for testing pool members. https://:9031/pf/heartbeat.ping The results should be “OK”. Is it possible to create a HTTPS based monitor using port 9031?
health monitor uses pool member port unless you specify the port number.
if you want to monitor pool member on different port then u can use dest *.portnumber
Hi Rob,
No it’s not part of send string. there is a seperate setting in every monitor. u can check with “b monitor https list”
b monitor https list monitorroot type https { defaults from none interval 5 up interval 0 timeout 16 time until up immediate dest : ignore down response disable enable is read only partition Common cert none cipherlist “DEFAULT:+SHA:+3DES:+kEDH” compatibility “enabled” key none password none recv disable none recv none send “GET /\r\n” username none }
e.g.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm monitor https myhttps
ltm monitor https myhttps {
    cipherlist DEFAULT:+SHA:+3DES:+kEDH
    compatibility enabled
    defaults-from https
    destination *:*
    interval 5
    ip-dscp 0
    recv "404 Not Found"
    send "GET /pf/heartbeat.ping\r\nHost: \r\nConnection: Close\r\n\r\n"
    time-until-up 0
    timeout 16
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:9031 {
            address 200.200.200.101
            session monitor-enabled
            state up
    monitor myhttps
 trace
[root@ve11a:Active:In Sync] config  ssldump -Aed -nni 0.0 port 9031 -k /var/tmp/localhost.key
New TCP connection 1: 200.200.200.11(58764) <-> 200.200.200.101(9031)
1 1  1397586345.7759 (0.0062)  C>SV3.1(514)  Handshake
1 2  1397586346.0500 (0.2741)  S>CV3.1(81)  Handshake
1 3  1397586346.0500 (0.0000)  S>CV3.1(1052)  Handshake
1 4  1397586346.0500 (0.0000)  S>CV3.1(4)  Handshake
1 5  1397586346.0527 (0.0027)  C>SV3.1(134)  Handshake
1 6  1397586346.0527 (0.0000)  C>SV3.1(1)  ChangeCipherSpec
1 7  1397586346.0527 (0.0000)  C>SV3.1(32)  Handshake
1 8  1397586346.2393 (0.1865)  S>CV3.1(1)  ChangeCipherSpec
1 9  1397586346.2393 (0.0000)  S>CV3.1(32)  Handshake
1 10 1397586346.2406 (0.0012)  C>SV3.1(69)  application_data
    Host:
    Connection: Close
