Hi all,
I´m trying to create a monitor that once connected do not disconnect and time to time send a string to the server and wait for a string.
I create it with a python script, it works with only one persistent connection when I´m running it in shell. But when I create an external monitor in big-ip, everytime it runs the script it kill all the processes and start it again.
I tried to create another script, that just call the main script and put it in background, but even this way big-ip monitor kills all related processes everytime it runs.
Below are my “monitor” that calls the main script that make all the dirt job… when I run it via shell it works fine but when it is called via monitor everytime hsm_monitor finish hsm_client.py also finish. Any suggestion to avoid this behavior?
!/usr/bin/python
import os
import sys
import subprocess
recebe as variaveis por parametro
serverIP6 = sys.argv[1]
serverIP = serverIP6.lstrip(“::ffff:”)
recebe o segundo parametro do comando que define a porta
serverPort = sys.argv[2]
if os.getenv(‘SEND’):
message = os.getenv(‘SEND’)
else:
message = sys.argv[3]
if os.getenv(‘RECV’):
resposta = os.getenv(‘RECV’)
else:
resposta = sys.argv[4]
filename = “/config/monitors/hsm_monitor_status.txt”
pidfile = “/var/lock/hsm_client_” + serverIP + serverPort + “.pid”
program_name = “nohup”
program_2 = “/config/monitors/hsm_client.py”
arguments = (serverIP6, serverPort, message, resposta)
command = [program_name]
command.extend(arguments)
command = “nohup /config/monitors/hsm_client.py " + serverIP6 + " " + serverPort + " " + message + " " + resposta + " &”
print program_2
print arguments
verifica se existe o pid file
if os.path.isfile(pidfile):
file = open(pidfile, ‘r’)
file.seek(0)
pd = file.readline()
file.close()
if os.path.exists(“/proc/%s” % pd):
Programa ja esta rodando, so coleta o status
file = open(filename, ‘r’)
file.seek(0)
status = file.readline()
if status == “UP”:
print status
file.close()
else:
Pid file existe mas o programa nao esta mais rodando, inicia-o
os.unlink(pidfile)
subprocess.Popen(command, shell = True, stdout = subprocess.PIPE, stderr = subprocess.STDOUT)
subprocess.Popen(command, stderr = subprocess.STDOUT)
os.system(command)
pid = os.fork()
if not pid:
subprocess.Popen(command, shell = True)
os.wait()[0]
else:
nao existe pid file, executa o programa
os.system(command)
pid = os.fork()
if not pid:
os.wait()[0]
Ukstin
