I was trying to configure persistence profile using HTTP Cookie Insert method. But I don’t have cookie option on F5 LTM, only have Source Address Affinity available. Check the screenshot below;
I tried to check to see if this is related with the hardware we are using or FW version (12.1.3.6) but couldn’t find any information to confirm.
Can anyone help about this, or had the same experience before?
Thank you! Ayhan
Go to Local Traffic >> Profiles >> Cookie and see default cookie persistence is available. That is default one and no one can delete that persistence.
If it is there try to restart below services and let me know the status.
tmsh restart /sys service httpd
tmsh restart /sys service tomcat
Thank you for your answer but there is no option like Cookie inside Local Traffic --> Profiles. I know that no one can delete default profiles, so I am curious if its about licensing or enabling/disabling certain features.
there is only one default available, source_addr, thats it.
hmm, wiered.
1. Can you please verify on different browsers through webui
On bigip.conf file you are able to see cookie persistence profile?
Can you please restart httpd and tomcat service and see whether it will help you.
hmm, wiered.
Is the LTM module provisioned?
You can check using the following command:
tmsh list sys provision one-line
Also check licensing:
tmsh show sys license
Here are the outputs;
tmsh list sys provision one-line:
sys provision afm { } sys provision am { } sys provision apm { level nominal } sys provision asm { } sys provision avr { } sys provision fps { } sys provision gtm { } sys provision ilx { } sys provision lc { } sys provision ltm { } sys provision pem { } sys provision swg { }
tmsh show sys license:
Sys::License Licensed Version 11.6.0 Registration key xxxxx Licensed On xxxxx Service Check Date xxxxx Platform ID Z100
Active Modules APM Base, VE, 200M (100 CCU,400 Access Sessions) Anti-Virus Checks Base Endpoint Security Checks Firewall Checks Network Access Secure Virtual Keyboard APM, Web Application Machine Certificate Checks Protected Workspace Remote Desktop App Tunnel SSL, VE
Hi Michael,
Thank you for the information. You are right we only have APM license but not LTM. Here is the info from F5;
Hi Michael,
Great, thanks for confirming.
I am glad you were able to identify the root issue.
