Persistence options for UDP Application
Hey Fellas,
I scoured the forums to find some info on achieving persistence for udp applications.
The VS I am using is standard, but the protocol profile is UDP with least conn - member as the load balancing algorithm.
I applied the default universal persistence profile and this irule but could not see any persistence records using
show ltm persistence persist-records virtual
when CLIENT_ACCEPTED {
    set src_IP [IP::client_addr]
    if { [session lookup uie $src_IP] equals "" } {
      session add uie $src_IP [UDP::remote_port] 1800
      log local0. "added client port [session lookup uie $src_IP] for client ip $src_IP "
      log local0. "existing client port [session lookup uie $src_IP] for client ip $src_IP"
Do I have to apply this irule to the VS or to the universal persistence profile itself?
The profile also has an option to include an irule!
Came across this
persist uie
command, can that be used with the current irule or do I need to change something more?
Also does the irule go to the profile or to the virtual server?
First why are you using
uie
persistence profile if you all you need/want is source address persistence? If you are using source IP then you do not need to make is this complex with
uie
and simply use source address.
Second the commands
persist
and
session
do different things,
persist
is purely for creating, looking up and removing persistent records (core session table records). The
session
is used for storing arbitrary/additional information in the session table.
Use
persist
instead of
session
for what you are trying to achieve, for example:
    if {[persist lookup uie $src_IP]} {
        persist uie $src_IP
        log local0. "existing client port [persist lookup uie $src_IP] for client ip $src_IP"
        persist add uie $src_IP 1800
        log local0. "added client port [persist lookup uie $src_IP] for client ip $src_IP "
NOTE: this is just a UIE version of source address persistence and at that more complex than needed as the following does the same:
    persist uie [IP::client_addr] 1800
