Persistence Issue
In version 9.4.0 I created an iRule that, when the LB selects a pool member, it checks to see if the node is “down”. If it’s in a down state, disable persistence and force the LB to select another member.
(I haven’t been able to test this yet)
when LB_SELECTED {
if { [LB::status] eq “down” } {
persist none
LB::reselect
Some background info:
When our Web Administrators need to do maintenance on a pool member, they are able to bring a pool member down by renaming a file that the health monitor is tied to. Thus, the node gets marked down and they then wait for the connections to hit 0 before they perform their maintenance. What we are encountering is that persistence allows users to get back onto the pool member even though it’s in a “down” state. Rather than having to manually force the pool member offline, I created the iRule above in an attempt to see if we can stop the persistent connections in a more automated versus manual manner.
Is this a good approach or s there another way to do this?
Here’s our current problem, we have another BigIP device running 9.1.2. LB::status is not available in that version, so I’m unable to get check the selected node’s state/status. Any ideas on how to address/approach this problem on version 9.1.2?
Thanks in advance!!
That looks like a good way to do it; certainly the most straightforward. LB::status (as the wiki page shows) is available in 9.1.2 HF4 and beyond, so you could just install the latest 9.1.2 HF (a good idea in any case) and get that functionality.
Thanks. Unfortunately, we have to get upgrades approved and scheduled, so it will a while before we can upgrade.
