persistence from http to https
Is there a way to keep the request to the same server when going from http to https?
Will i have to implement an irule or can it be done simply with one of the standard persistence profiles?
your help is much appreciated.
cheers !
Manjit
Yes, you should simply need to use cookie persistence which can be selected on the virtual server. You will likely want both virtual servers (one for port 80 and one for port 443) to have the same pool and use cookie persistence. However, you will need to unencrypt the ssl connections on the BigIP so it can inspect and use the cookie.
