From the same source but for a different session we need to load balance with out any time out (180 sec). Also even after 180 sec, if the request comes from the same session, the request has to go the same destination with out change. Only the next session can change the destination.
If you are not sure about the persistence profile to utilize, I would recommend “cookie insert” as the default persistence profile to try out initially. Depending on any specific lack of function, you can explore other persistence profiles.
Use Cookie insert with a OneConnect profile
